Sonikete
- Jul 29, 2014
Does Fiio x3 sounds good with earphones such as vsonic gr06?
I´m not expert on this matter. I´ve just bought an Ipod nano. After read so many positive opinions about Fiio x3, I´m considering to return ipod and get Fiio x3. Do you think is this a upgrade of sound quality?
Thanks
Any headphone you buy for under $100 will work fine with the X3. It's not until you get up to much more expensive, very difficult to drive headphones that you might wish you had a more powerful amp.
Yamaha PRO-500's cost well over $100 but taking into consideration their exceptionally low impedance -only 23 ohm's- I expect them to be driven sufficiently by the X3.
