chicscantdrive
- Aug 13, 2009
You're criticizing me as if I even made a headset recommendation. I also explicitly stated that I did not own all these sets.
But yes, I put on the K702 when I want accuracy. But no, accuracy isn't the only thing I enjoy. But why would I ever buy more than one neutral can? It's too much like buying the same product twice.
I would never buy the K1000 because it makes you look dumb. I'll buy the HD800 when the price comes down.
Originally Posted by moonboy403 /img/forum/go_quote.gif All the bolded headphones are well-known to be colored cans so you should've done better research than you have in getting those cans. I don't have much experience with the HD600 so I'll refrain from commenting. As for the K702, it's certainly not truly neutral as it tends to have a treble emphasis and there's also something a little off on the mids IMO. So out of all the ones that you've tried, only the K702 and HD600 can be considered neutral really. You mentioned that headphones don't matter much since they are very colored, that's probably because you picked out all the highly colored headphones to begin with. Now if you want truly neutral cans, try the K1000 and HD800. ![]() |
