yes, XB700 pads indeed! well, they're uber-comfy
don't waste your time w/ dynamat IMHO...it's mostly tar w/ a piece of aluminium foil on top so it's heavy and not too good to breathe/have in contact w/ your ears sweat and so...and the aluminium foil will give very harsh trebles.
you can DIY far better equivalents if you're after something that doesn't allow the cups to resonate and kill inner-cups resonances all at once...I did MANY tests, and the best I found was to use some super-thick dual sided adhesive for carpets, glue some egyptian papyrus on one side, and then glue it inside the cups...many advantages:
-the thick rubber tape won't allow the cups to resonate whatsoever, and it won't fall off after a few weeks due to sweat
-the papyrus is completely immune to moist
-it's also not flat at all, so the inner back waves are "broken"
-it's vegetal...like the cd3k cups that are made of a mix of plastic + bio fibers...it's good for sound hummm'kay
I wouldn't advise to completely cover the inside of the cups, because then there won't be any resonance anymore and the sound will be very harsh and feel like the inside of a studio cabin...you need to find the right in between, a big round piece behind the driver and that's it.
like this basically:
DynaXorb
anyway, modding phones is a hell lot of fun, so go to SAINT-MACLOU, get the baddest thickest tape you can find and get going already
there's also tricks to play around w/ the low end bass/trebles FR...modding phones allows to make them tailor-made to your very own taste. I personally like crystal clear non-shrill trebles, and a very tight percussive bass, but not V-shaped whatsoever, do want mids!
