You may be right.It won't be bad, the maximum output power @62Ohms will be around 250mW wich should be plenty for the 7xx. I just think you'd miss that OTL magic...
Best AMP for K7XXs
chef8489
- Jul 1, 2005
I Am quite pleased with my modi multibit and vali 2 and vintage tubes. You have pleanty in the budget for some tubes to play around with and get a warmer sound.
TheBaaron
You think that would be a viable option though? Better than Modi Magni and the NFB 11.28?It won't be bad, the maximum output power @62Ohms will be around 250mW wich should be plenty for the 7xx. I just think you'd miss that OTL magic...
Whatever amp you go with, the Modi Multibit is really a significant upgrade over the Modi 2. If you can afford it, it's worth the upgrade IMO.You think that would be a viable option though? Better than Modi Magni and the NFB 11.28?
TheBaaron
What do you guys think of the dark voice?Whatever amp you go with, the Modi Multibit is really a significant upgrade over the Modi 2. If you can afford it, it's worth the upgrade IMO.
chef8489
- Jul 1, 2005
THe darkvoice is not a good match with the k7xx.What do you guys think of the dark voice?
Carcajou
- Sep 17, 2016
Viable, yes. But IMO you'll like the magni 2 or the Vali 2 more. I agree with Chef8489 on both his statements. The Vali 2 is a good pick if you want tubes and a far better match with 7xx than any OTL amp such as the darkvoice of the Valhalla 2.You think that would be a viable option though? Better than Modi Magni and the NFB 11.28?
TheBaaron
Ok, thank you. The only reason I ask is because I have heard a couple reviews saying the Vali 2 is not really a tube amp, and that the tubes don't do much because its a hybrid. Thus, they found it didn't have much warmth over a solid state like the magni.Viable, yes. But IMO you'll like the magni 2 or the Vali 2 more. I agree with Chef8489 on both his statements. The Vali 2 is a good pick if you want tubes and a far better match with 7xx than any OTL amp such as the darkvoice of the Valhalla 2.
Carcajou
- Sep 17, 2016
It's true that it won't give you that tube sound like an OTL or a higher-end hybrid tube amp like the Lyr 2 or Mjolnir 2 would, but it'll still give you that added warmth you're looking for, especially if you get a good NOS tube like chef8489 recommended. Schiit's default tubes are pretty dull so what you say might be true if you're comparing it straight out of the box.Ok, thank you. The only reason I ask is because I have heard a couple reviews saying the Vali 2 is not really a tube amp, and that the tubes don't do much because its a hybrid. Thus, they found it didn't have much warmth over a solid state like the magni.
TheBaaron
What tubes would be good and how much are they?It's true that it won't give you that tube sound like an OTL or a higher-end hybrid tube amp like the Lyr 2 or Mjolnir 2 would, but it'll still give you that added warmth you're looking for, especially if you get a good NOS tube like chef8489 recommended. Schiit's default tubes are pretty dull so what you say might be true if you're comparing it straight out of the box.
TheBaaron
Also, what do you think of the little dot 4?
Carcajou
- Sep 17, 2016
It uses a 6922 (aka ECC88) tube which are probably among the easiest to find. What would be good really depends on your preference, I recommend you read the Vali 2 tube rolling thread: https://www.head-fi.org/threads/vali-2-tube-rolling.793982/What tubes would be good and how much are they?
Prices are going to vary between $10 to several hundreds, but something north of $20 should be an improvement over the stock tube (again it's always a matter of personal taste). I really like the JJ E88CC/6922 Gold ($25). I find it really delivers great performance for the price, although it's not nearly as warm as a good NOS tube.
Carcajou
- Sep 17, 2016
Again it's an OTL... I have the mkii and I really like it with my Beyerdynamic DT770 250Ohms, so I'd assume, based on what I've read, that it should be pretty good. But it's still not a good match for your 7xxAlso, what do you think of the little dot 4?
TheBaaron
A drop on the mkii https://www.massdrop.com/buy/little...ontent=1502107873163.885880163003226552170824 said the recommended impedance was 32-600 ohms.
Carcajou
- Sep 17, 2016
It will work with 32 Ohms headphones, It just won't be as enjoyable as it would be with higher impedance headphones. It's not because an amp is rated at a given impedance that it'll sound good.A drop on the mkii https://www.massdrop.com/buy/little-dot-mkii-tube-headphone-amp?1=1&utm_placement=1&referer=6C8VE5&mode=guest_open&utm_campaign=Automated Daily Promotional 2017-08-07&utm_source=SparkPost&utm_medium=email&utm_term=Daily Promotional&utm_content=1502107873163.885880163003226552170824 said the recommended impedance was 32-600 ohms.
