servingecuador, "Actually, the RKV is set-up to run high impedance stuff, so the impedancer is only for running the RKV with low impedance cans!! Since the K1000s have a resistance of 120 ohms, I think it would be better to run the RKV directly into the K1000s."
this is only half true. the k1000's are not normal headphones. yes, their impedance is 120ohms, but they were designed to be powered by low impedance power amps.... you can read Millet's posts for specifics.
.......hmm, perhaps i'm getting deaf?...heh he..i dunno, but it is my experience that 15wpc is optimum. i haven't tried the other 8ohm amps yet. i know power output isn't always perfectly linear in comparison with impedance.... so it's possible that those 8wpc amps actually output more than expected at 120ohms. but one thing for sure--my amp works perfectly well with the k1000's. i have no complaints.
oh, RVD, so you know... both the ASL and the Tube City can be had at used prices for just a couple hundred more than the RKV new OR USED. so, i say, don't limit your choices too much... i know someone here got the ASL for $800 used, and I personally got my Tube City for significantly more than that, but not an unaffordably large difference. and those 300b tubes sure are beautiful with the lights turned off... especially those Sophia mesh plates....
