peskypesky
Does any know the difference between the KZ ZS5 and the KZ ED12?
totally different designs
the ED12 have a single 10mm dynamic driver
the ZS5 have two dynamic drivers (10mm and 6.4mm) and two balanced armatures
Can anyone tell me weather to get the S5b or K9(The bluetooth one) .I just received the bluetooth cable for my ZS3 and looking for a DAP with bluetooth.
Ok thanks will keep it in mindThe s5B sounds great but not every headphone is the same so I want to have freedom with sound settings in a custom equalizer.
I have the 5SB and ordered a T6 with equalizer. If the k9 has an equalizer maybe I would go for the k9 instead of 5SB. Just my opinion.
Using the bluetooth on the S5b is a pain in the arse. Don't know if its easier on the K9....but man, the S5b is not user-friendly when it comes to bluetooth. I love just about everything else about it though.Can anyone tell me weather to get the S5b or K9(The bluetooth one) .I just received the bluetooth cable for my ZS3 and looking for a DAP with bluetooth.
there's the Ruizu X18Hi,
I have the S5 and i want to buy another player for bluetooth. What you recommend between S5B, K8 with BT, T6 or if there are any other option to use with BT headset.
I know but it looks cheap and the price is close to S5B.
Just got the Benjie K8 today. Sound quality roughly as good as the K9. The Bluetooth sounds OK through my audsoms but the interface, yuck. You enter the Bluetooth menus and pair your device, but then you have to access music only through options within the Bluetooth menu. You can get to music organized by indexed categories, but if you want your playlists or to access via folder you can't do that. I have not yet tried accessing music on SD card via the Bluetooth. Try to exit the Bluetooth menu and your device gets disconnected. Want to listen to FM radio on Bluetooth? Can't do it. Personally, I use playlists extensively. I also like to listen to the news when I run. Can't do either of them on the K8. If this is the kind of BT implementation necessary to keep the price low, I'd say it's not worth it.
My T6/K1 firmware is 1.04 Beta
