Ferbose
- Jun 27, 2004
Despite several users chiming in on this thread, nobody has yet made a head-to-head comparison between two ways of connecting headphone from DAC1's XLR:
method 1: Use an ordinary XLR->RCA adapter (Pin2->Signal, Pin1&3->Ground)
method 2: Float Pin 3 (Pin2->Signal, Pin1->Ground)
My previous post is based on method 1. But DAC1's engineer and manual suggest method 2. In order to see if there is a real difference, I decided to conduct the experiment myself.
I bought altogether four Hosa XLR->RCA adapters from sweetwater.com
http://www.sweetwater.com/store/detail/GXF132/
The adapters are wired as method 1.
Some of these adapters can be loosened by hand, so you can directly look at the soldering inside. Others are hard to open and may require clamps.
Anyway, I opened two of them and used a swiss army officer's knife to saw off the solder between pin 1 and 3 (foutunately the wire is soldered to pin 1 and pin1->pin3 is connected by a thread of solder). The solder material turns out to be harder than I thought, so it took about 10 min to cut through it.
After this modification, I have two adapters connected in method 1 and two in method 2, and a direct comparison can be made.
In a nutshell, I can clearly hear differences between the two connection methods. Not surprsingly, method 2 sounds better. DAC1 manual says not floating pin3 causes " very high levels of distortion," and that is an EXAGGERATION. I did not detect any difference in tonal quality in any frequency range, so basically the both methods sound very similar. However, method 2 has an slight edge in terms of details and resolution. The differences are quite small in absolute terms, but in terms of creating an audio illusion, the improvements are significant. With method 1, the XLR is already a noticeably better headphone amp than the headphone jack. With method 2, another level of refinement is added. If method 2 scores 10 in terms of sound quality, I would say method 1 scores 9 and headphone jack is 7.
In the next follow-up post, I will describe some of the very intriguing sonic results I am able to hear with method 2. Details of associated quipment and comparison method will also be described.
