EliasGwinn
Member of the Trade: Velidoxi & Benchmark Media Systems
- Feb 26, 2007
Hello Bizkid...
Any potentiometer that has a 'full-off' position will have a short range at the beginning where the channels don't track well. This is because the wipers are completely off the elements at 'off', and the first part of the range is the steep part of the logarithmic curve.
The potentiometers we use track very tightly after the first 10-15% of their range. If your's isn't tracking well beyond the first 10-15%, your unit may have a defective pot.
I'm not sure I understand your testing procedure, but it sounds like you were ABX'ing the SRC performance of the software. The DAC1 will resample everything to 110 kHz, and the performance of that SRC won't vary based on the incoming sample rate.
Can you describe in more detail how you determined your opinion of the DAC1's SRC?
Thanks,
Elias
Originally Posted by bizkid /img/forum/go_quote.gif I've owned the DAC1 USB for some months now and basically i'm happy with it. However there are 2 things where i see the need for improvement. First the easy one, the volume pot. Atleast on my DAC1 the L/R Balance varies more than i'd like throughout the range. That means the headphone out is unusable if you don't attentuate the volume in the digital domain to reach the (very small!) sweetspot of the poti. That's just not good enough for 1300 Euro, sorry. |
Originally Posted by bizkid /img/forum/go_quote.gif The second one goes a little deeper, i'm not happy with the resampling algo that is used, especially since EVERYTHING get's resampled to the DACs optimal rate (which makes sence) and there's no way turning that off thus limiting the DACs capability. The problem is that the resampling algo in the DAC1 doesn't appear to be a good one, atleast sonically. You can see measured comparisons of various resampling soft/hardware here: SRC Comparisons Yesterday i ABX'd a propper resampled 96khz file and the original 44khz file (thus the DAC1 has more resampling to do). Out of 10tries i scored 100%. |
Thanks,
Elias
