bizkid
- Jan 18, 2006
The internal attenuation of 10dB isn't even enough for the HD650 or 600 Ohm Beyers to reach the sweet spot. And imho the attentuation is just a cheap fix to a whole other problem, the poti itself. Come on i've seen better pots in sub 250$ china gear.
Please do a research on measuring resampling and see yourself what results you get by upsampling from 44khz to 110khz (or higher ie 192khz) straight with a so-so algorithm vs 44khz -> good resampler to 96khz -> to 110khz (via same or worse algo). Its much less of a problem to go from 96khz to any higher rate even with an average resampler.
The website also offers comparisons of hardware implenentations, very expensive ones.
