ProtegeManiac
Woo says that tubes last for about 5000h
"15: How long do vacuum tubes last?
No reputable tubes seller can guarantee the life of a vacuum tube. Typically, tubes in our products may run 5000 - 9000 hours depending on where they are used. Drive tubes (the smaller tubes) are generally last up to 9000 hours, and power output tubes (the larger tubes) about 5000 hours. They do not usually completely fail after this time, but gradually deteriorate as the cathode begins to lose its coating and cannot emit electronics at the maximum rate. The sound usually becomes less focused and 2D like lacking high frequencies response."
https://wooaudio.com/faq/ and I'm running my system for 6h per day on average that would be about 300$ + tax every 2 years.
It doesn't matter if they say 5000, 50,000, 100,000, or 1,000.
My point was that your use of "tubes....degrade" vs "op-amps either work or not" is problematic.
Tubes either work properly or they not, just like opamps. No manufacturer guarantees that the op-amps will continue to work after 10,000hours, and calling the process leading to tube failure as "degradation" is highly inaccurate because your implication of contrasting it vs opamps that either work or don't work suggests that you think the performance degrades on a tube that has been used already. It does not. You can hit 5000hrs or whatever or not, but the tube does not have its performance degrade until you're close to whatever the amp manufacturer says about a specific brand and tube type on their amp. A tube that has been used for 30mins has not had its performance degrade in that 30min use time frame any more than using a chef knife once and sharpening it will end up with such a ground down knife that it's now a carving knife for roast meat or a needlessly long petty knife. Either it works or it doesn't, just like opamps.
Giving you a time frame of 5000hrs or whatever just gives you an expected time frame to order some new tubes if you don't stock tubes, whereas your no time frame op-amp can fail at any time, even sooner than tubes would have in some cases. The work of diagnosing and soldering is irrelevant for you with your skills, but tube price and in some cases, they might be hard to find, will. I'm not pushing you to get a tube amp over the Meier, all I'm saying is that knowing a rough time frame for tube death isn't the reason to decide against it and your contrasting of "tube degradation" to "opamps either work or not work" is extremely inaccurate.
What this is like is deciding between a DSLR or true rangefinder and a mirrorless camera based on how the former only has a mechanical shutter but also has those mechanisms to move the pentaprism or the rangefinder mirrors, but the latter has an electronic shutter and an EVF. The DSLR and rangefinder have rated life for the mechanical shutter from the manufacturers, the mirrorless camera has an alternate electronic shutter just like compact digital cameras. You can't just base your decision absolutely on Nikon telling you that you can only get 150,000 exposures out of a D800E vs Fuji not saying when their mechanical shutter will fail but gives you an optional electronic shutter when:
1. Electronic shutter does not work with artificial lighting, either ambient or speedlights, unless you set it really slow (ie, as slow as compact cameras and smartphones) to make sure you don't end up with those shadow lines (it's from how the pixels in the sensor scan the image by line which shows the frequency wave of artificial lighting).
2. The EVF and electronic shutter can also fail, just like the mirror mechanisms and mechanical shutters
3. Nikon has a system in place to quickly have the mirrors replaced, even if your'e not a pro photog; Fuji does not (they used to...through Nikon, since their DSLRs were Nikons using Nikon F-Mount lenses), Olympus no longer has this in place since 4/3 died out for micro4/3, and for all I know maybe also Sony since they also dropped the Alpha line and A-Mount.
4. Weight, lens selection, and prices of bodies and lenses are far more important than being scared of Nikon admitting you can only get 150,000 or so exposures out of their DSLR.
Also, a camera with 50,000 shots taken does not take crappier images than a camera taken out of the box, ie, it does not degrade. It either works or doesn't work. Yes, it degrades in terms of known service life. No, performance is not impacted as to be contrasted with something else that "works or does not work." Same way that a primary knife that is 46mm tall at the heel will dull when you bang it on the cutting board enough times, at which point it needs sharpening, but no, the knife will not just end up so worn down that it is now a 25mm tall carving knife.
Cost is the more important thing but don't contrast tube degradation to solid state parts that "either work or don't work." Degradation is just going towards its death, not that a few hours of use means its performance has measurably decreased. Tubes also either work or don't work properly, and the only difference to the end user is the cost and ease of acquisition and replacement. Op amps can fail in 5,000hrs or 100,000hrs, you never really know for certain. The difference there is you can get op-amps for practically a few bucks, and you have the skills and equipment to diagnose whether it's the op-amps or some other components, and solder.
On a different topic I was searching head fi for reviews of CORDA CLASSIC-ff, there aren't a lot of -ff version reviews, but there are a lot of standard version reviews, and some people have found Classic lacking when paired with low impedance (planar) phones.
That's because more power can be head for less, like the Schiit Lyr. That's why I said 90dB/1mW and above a couple pages ago or so - you can run an LCD-2 or HE400 on it just fine, but not the older planars with 86dB/1mW.
I have also found a few glowing reviews of the HeadAmp Gilmore Lite Mk2, what do you think of it? Maybe it would work well with Daccord.
AFAIK it doesn't have significantly more power than the Classic, FF or not (and probably a little bit less actually).
