ProtegeManiac
Already did it with opamps
I used stock LCD-X, also my friend who is an audio engineer confirmed it.
So is the bas wobbly? If not you should try it with other headphones because that's an Audeze. Even with newer LCD headphones they're not exactly going to have that much treble, and if you're used to how "normal" sound has peaks in the upper midrange and treble, then it will always sound "bassy" even if the bass isn't distorting.
They also make Niimbus, their sub brands are meant for different markets. I think that Violectric is designed for people who want more colored sound and Lake people for more natural sound.
You'd be surprised at what "Natural Sound" is like to most people who use that term. Try looking for a car using DLS speakers and doesn't have a full active set up. They have a giant "Natural Sound" sticker on the back and the sound is generally what you describe as described by people listening to Focal with higher sensitivity and an upper bass peak or people listening to JBLs which scratchy treble (Focals can have that too but that's why people replace that one tweeter they used with something else).
Opamps are and can only be class A, but they are used for signal manipulation, not power amplification. From this photo of Classic's internals it looks like it's using 3 voltage regs (one per power amp) and power amps with 2 active elements which would indicate that it's class A/B, and not class A, but I'm not completely sure about that, part numbers are hard to read in that photo.
Op Amp power amps have been around since last decade and they're used on the amplification stage. Yes, that's not what they're originally designed for. But that's what those amps use them for, like the LM3886 amplifiers for speakers that jump started a lot of this.
Used that way they're sometimes wired up to have more Class A bias, which is what Meier does. It's not full Class A as with discrete components (ie why I say "running in Class A" as opposed to calling it a Class A amplifier outright), but they won't call it Class A/B either because it takes more to get it to switch over to Class A/B. In some cases, like with Meier, it's properly implemented and therefore works. In other cases like Class A biased op-amp kits for people who roll op-amps like they roll power tubes, not really...most of these kits actually increase the noise and the tonality changes too much in some amps with some kits, which basically torpedoes the whole point in using Class A in the first place.
