Aischilos
- Aug 20, 2016
And I thought that my search over the Internet for a proper case was exhaustive.... Should have known better
First impressions. I too have a continuous ticking sound from the left ear pad. At first it was a short lived one. Sometimes it may persist for as long as the whole song. I used poweramp as music player and the beoplay app for the equalizer setup. The beoplay app has connection issues when I use Napster or poweramp as players. When I connect to beoplay, and then use the music player the beoplay app loses ability to change the equalizer settings I have to restart the s7 edge, and the set and run the app again.
Other than that, the set was fully charged, did update although it is supposed to be 2nd gen, paired with my mobile easily. Music? Tried most of what I intended and remained impressed, However if the ticking persists I will return it and depending on the answer of Amazon UK whether it is 2nd or 1st gen. I may have to let it go.
Hi, could anyone who has recently (latest 3 months) bought the H7 confirm the bluetooth version the box says on the outside? Mine (the replacement I received from amazon uk, so called 2nd gen) says on the box "bluetooth 4.0".
Can anyone confirm that beoplay software updates are about the bluetooth version too (eg going from 4.0 to 4.2)? How can I verify the BT version of the set I currently have?
Thx
Same here but you haven't asked why it isn't 4.2 as advertised on the beoplay site?
