Thanks, music_man! I've been just burning in 24/7 but already it has this bloom to certain recordings that I find very attractive for the types of music I listen to.
I don't have much DSD, mostly redbook and hi-rez PCMs from Linn Records, so not having 4x DSD is no deal killer for me.
A couple questions - you recommend a good hub/filter/lps/XLR cables - can you explain and also recommend me your personal choices? I'm just connecting my work PC/laptop to Codex via Wireworld Starlight Platinum 7 USBs, then out to my Z1R cans (currently thinking of rewiring balanced by Wireworld, to keep things synergistic). Shall I add Regen to the mix? Also don't understand how XLR cable fits into this chain. Plus I thought Codex already has linear power supply built in, but does an outboard LPS make it better? Please let me know if you ever do swap in 9038 Pro and see if there's discernible difference. But I have a good feeling about this DAC/amp as it is; will take it home once it's broken in to compare vs. Yggy.
Apologies for a ton of questions! =D
