cygnusx
- Mar 20, 2016
Getting two 3.5mm adapters should do the trick. One word of advise, be patient with the break in time. The Codex needs 300+ hours to break in. It will be worth the wait. Good luck
Waiting for my Codex to arrive, hopefully by the end of next week. I have a balanced Silver Dragon cable terminated with 2 xlr 3 pins. Can I just buy two generic xlr to 3.5 mm adaptors in order to use it with the balanced out of the Codex?
Talk to Drew at Moon Audio. They can either sell you an adapter, or you can send in your cable for retermination.
Could you write something about your experience with codex?Waiting for my Codex to arrive, hopefully by the end of next week. I have a balanced Silver Dragon cable terminated with 2 xlr 3 pins. Can I just buy two generic xlr to 3.5 mm adaptors in order to use it with the balanced out of the Codex?
I wish I could! Apparently there has been some delay from Ayre...still waiting for mine to arrive...
Still wondering if I can use two not expensive XLR 3 pins female to 3.5mm male to convert my balanced cables terminated with dual xlr
Is anyone using this with a DAP as the source? Something like a Fiio X5iii maybe. Everything I read seems to suggest maybe you need to use a computer with drivers so I was just curious if anyone had DAP experience with it.
you can use the xlr pins on the back of the codex by getting a female to female xlr adapter (I assume your cable has male xlr pins at the termination.Waiting for my Codex to arrive, hopefully by the end of next week. I have a balanced Silver Dragon cable terminated with 2 xlr 3 pins. Can I just buy two generic xlr to 3.5 mm adaptors in order to use it with the balanced out of the Codex?
btw--if you decide you like the back xlr outlets you should eliminate the adapter by reterminating the cables -- the adapters I tried could all be "heard" in the chainyou can use the xlr pins on the back of the codex by getting a female to female xlr adapter (I assume your cable has male xlr pins at the termination.
when you use the codex in preamp mode (volume control active) the circuits are the same (according to codex) but the cable is much more secure in the back than in the 3.5 mm sockets in the front and banging into one of the cables doesn't fool the codex into thinking you've changed your headphones and going into low volume mode to "protect your ears"
codex sounds much better balanced than single ended
Jeff
