elnero
Same actual nozzle diameter as our ASG series so the larger comply tips should work no problem. Will get them certified for comply tips soon also if you want to use foam. Tips you have used in the past may say silicon but may not actually be depending on where they were manufactured. Ours are medical grade real silicon.
Thanks for the reply. I gather by larger Comply you mean the T400 and 500 series?
I've tried an awful lot of IEM tips during my many years on Head-Fi, the only ones that don't seem to bother me are foam based but if I get a pair of Rockets I'll give the included tips a try to see how I get along with them.
