koso
Aries is conected to DAC input, it has nothing to do with output voltage of DAC. It is definitely issue with Aries alone, wrong settings or some software bug. What connection do you use?i’ve been using my aries g2.1 with metrum hex dac with 4v xlr outputs.
i just received my holo audio dac with 5.8 v xlr outputs.
when i plugged the aries into the dac i found the volume level had decreased.
when looking at why i found the aries was still showing 100 volume but it was no longer adjustable.
i then used the lds software to disable and enable hardware volune setting and that solved the issue of low volume and not being able to adjust aries volume (which I don’t).
when i plugged in this dac with the higher output it appears the aries volume adjustment dropped to (say 50%), froze and still showed volume at 100%.
Anyone know if this is a protective element of the aries or did it just “have an attack”
