Marlowe
The chassis is not completely enclosed--there is a narrow bank of vent perforations on the rear along the top left edge above the input/outputs and a smaller bank on the right above the power switch; Aune's website notes them as part of the cooling system. They are unobtrusive and easy to miss and (with the caveat that I am far from an engineer) appear inadequate to vent the amount of heat that the S17 produces. (In contrast, the Class A Schiit Mjolnir 3 has much more extensive venting on the top and sides and almost the entire external surface of the Class A Burson Soloist is a finned heat sink. Frankly, this may partially explain why the S17 can compete with these more expensive units on sound quality at a significantly lower price.) Ditto for the very short feet, which are a stock component of the S chassis and should have been replaced for this application. (After unboxing the S17, even before I plugged it in, the first thing I did was add extra tall aftermarket feet that raised it almost an inch above my Denafrips Ares 12th-1. BTW, I've been criticized for this stacking, which is necessitated by my space limitations, but the Denafrips only gets slightly warm and remains significantly cooler than the S17.)The problem was wanting at all costs to maintain that typical design of their S series (which they have been using for many years now) for a device that would have at least needed ventilation grills on the top. Unusual is to build a pure class A amplifier inside a completely closed enclosure. Class A amplifiers operating at maximum voltage need at least multiple ventilation grills or adequate dissipation systems with noticeable external fins that release heat. I'm in Italy and it's cold now and maybe it could work but as soon as our very hot Italian summer arrives it will be possible to use it in 100mha mode for no more than 5 minutes maximum.
