There are 1032 defective in 1827 sold. Only not sure if the one I bought is one of the 1032 or one of the others.How many defective units are there, and how many has been sold? @MiguelP
![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
one thing I noticed, there is some differences between their website picture and actual unit.The most reasonable explanation for me is that the product has a poor design (heat dissipation not compatible with the 100ma mode). Apart from that there some (many) defective units that are not able to produce 100ma (even if so is stated in the display) so their owners are happy with their product because ignorance is a bliss. Of course Aune should come and explain the different behaviour between units, but only thing that they do is emit some vague comments.
When i contacted the manufacturer, they confirmed the unit is possibly defective. I contacted the seller and forwarded email conversation. AliExpress seller said they also contacted the manufacturer, seller said Aune confirmed the unit is very normal.Open a dispute at AliExpress because the seller sold you a defective product.
oh, you are right. bad eye. sorryI think he removed it. You can see it in the frame you've posted.
I managed to solve the issue with my "defective" unit by myself. Turned the AC on to 25 °C and the unit temperature stays stable at 63 °C. Listened for one hour with Sennheiser HD800s and I'm into 25 minutes of listening with Hifiman Arya Stealth. The unit is at 63 °C since 44 minutes. Different cables, headphones, volume have no effect whatsoever. Since most users probably have room temperatures way below mine, I'm guessing that they are only going to find that their unit is defective in the summer months (or never if they use AC).In post #933 Aune is very clear with the below statement:
“Hi, if there's a problem of your device, we recommend you to contact your seller to test it. If it's malfunctioning, you may need a repair or replacement.”
Nothing ‘vague’ in that statement, to me.
No.one thing I noticed, there is some differences between their website picture and actual unit.
below captured image from youtube
this one is from their website
Big heatsink is missing on actual unit.
The total production quantity of the S17 Pro up to now is only 800 unitsThere are 1032 defective in 1827 sold. Only not sure if the one I bought is one of the 1032 or one of the others.![]()
For music we design.
Stay updated on aune at their sponsor profile on Head-Fi.
The problem was wanting at all costs to maintain that typical design of their S series (which they have been using for many years now) for a device that would have at least needed ventilation grills on the top. Unusual is to build a pure class A amplifier inside a completely closed enclosure. Class A amplifiers operating at maximum voltage need at least multiple ventilation grills or adequate dissipation systems with noticeable external fins that release heat. I'm in Italy and it's cold now and maybe it could work but as soon as our very hot Italian summer arrives it will be possible to use it in 100mha mode for no more than 5 minutes maximum.Class A amps reaching over 65C is not anything unusual, though it may hurt the lifespan of the components. Problem here is that the amp won't let you use 100ma to prevent it from overheating which might have been one of the selling points of the amp.
Was the s17 standing on a stone plate? What was the relative humidity at 18C?Max temps, that I have been hitting in 100mA mode, are 59C-60C after about 2 hours of listening. Room Temp was around 18C.
Then there are only 800 "defective" unitsThe total production quantity of the S17 Pro up to now is only 800 unitsWhere did you get your numbers from...?
Playing through a difficult to drive headphone will only increase the temperature as this is a class A amplifier which will get warm even with no input or output. There are 2 power settings 50 and 100 and when you use the amp on the higher 100 setting it will get significantly hotter. When it reaches 69 degrees C the amplifier should automatically reduce the power to 50 to reduce the temperature. I hope this helps as it's a superb sounding pre amp and headphone amp but it will run hot and use more electricity than a class A/B or D amp.This makes it run hotter. Plug in a headphone that actually needs power, crank up the volume, and it should run significantly cooler.
