Thanks everybody for all the feedback and support. We are so glad and thankful that you like the sound of the S17 Pro which we made with our heart
To reply to the issues you may be concerned about:
1. The volume control of the S17 Pro is composed of an R2R chip and has 64 steps. The S17 Pro is mainly designed for large headphones. When we received user advice on volume, we took it seriously and have optimized the volume curve.The units now all use the new volume curve.If you are an earlier buyer and if it bothers you, please contact us via Email sales@auneaudio.com for a volume upgrade.
2. The S17 Pro is pure Class-A. Both 50mA mode and 100mA mode are class-A. There’s no Class-AB.
3. The 100mA mode of the S17 Pro is like the GT mode in a car, where the maximum throttle is engaged, and the car's continuous extreme mode also leads to significant energy consumption. In 100mA mode, there’s 0.2A per channel, even without headphones connected. The temperature rises noticeably faster compared to 50mA mode. High ambient temperatures and low impedance headphones can cause even faster temperature increases. Setting the jump to 50mA at 69 degrees is to ensure the stability of the device, similar to the restriction of maximum engine speed in a car. As long as the temperature is below 69℃, you can enable the 100mA mode again.
4. Any true Class A amplifier will have thermal noise due to the continuous presence of 100mA static current. The S17 Pro is already a well designed one, with a noise floor of only 4μv which is extremely low.And, as the S17 Pro is just an amplifier, if the front-end equipment has a noise floor, it will cause the S17 Pro to exhibit noise as well. If you are experiencing severe issues, please check your front-end audio source.
Hope the information helps.
Thanks for all your support. May music and joy always be with you
For music we design.
Stay updated on aune at their sponsor profile on Head-Fi.
