Guys, which gain setting do you use? I've always followed the rule that if the headphones are loud enough, use low gain to reduce noise. Well, my most demanding headphones, the Edition XS, are certainly loud enough at 30-35 volume in low gain for most situations. However, the EF400 worked differently; high gain increased not only the volume, but also the impact and dynamics. I used it as the default setting. What about the S17?
Ok. For now I'm using the XLR-RCA connection until XLR-XLR arrives.
It's SO GOOD, so powerful! The impact and dynamics on this brick! The soundstage! The amplifier on the ST-AMP is no slouch, nor is on the EF400, but the way my neutral/brigth(ish) headphones sound on the EF400 > S17 is great. I drafted a short comparison between the ST-AMP and the S17, but then realized I almost repeated what
@Ichos already said, same impressions. So let me just quote it:
The difference in impact is quite significant. Even comparing to the EF400 solo, which already has a powerful sound presentation. Lots of body, no fatigue. I really like it.
Interestingly, I preferred the OS mode with the ST-AMP as it adds more heft and warmth, but with the Aune I much prefer NOS, which is a true R2R mode. This seems to confirms the notion that this amp pairs very nicely with R2R DACs like the EF400.
Comparing the S17 to the EF400 solo:
1. Even more impact.
2. Shoutiness gone.
3. Sibilancy gone.
4. Mids hollowness gone.
5. Just as big if not bigger soundstage, but better extended, layered and more 3d.
ST-AMP is also able to take care of points 1-4, but to a lesser extent and with a much less weight.
About temperatures: It stabilized at 59°C in 100mA mode with my 1.4m Openheart 16-core balanced cable, low gain, volume 32. I'm quite happy with that.
However, the unit is elevated sitting on some LEGO blocks for testing
At first, when I placed it directly on my desk and stacked the EF400 on top, it reached 65°C in 3 hours and continued rising. No doubt it would keep going and throttle at 70°C. It was already too hot to touch, especially on the bottom. So I removed the EF400 and placed the amp on LEGO. The temperature dropped by 5°C in 30 minutes just by doing this.
I also added a USB fan underneath the unit, so I can activate it with the wire control if the temperature exceeds 60°C, which I aim to prevent. I tested it, and it cools it down quickly, then it takes another 1-2 hours for the temp to go back up. Like
@SpiritualAbies2600, I'm going to turn it on/off when needed.
Overall, it's a great purchase. I bought lots of stuff in the last few months but don't remember being so happy.
