Skyfall
Member of the Trade. (Cable maker)
- Jun 3, 2014
On my way out with my portable rig Aune M2 > Neco soundlab V4 > DT1350 I walked past my tube amp with DT880 600 ohms and thought what if? so I plugged the DT880's in place of DT1350's and wow! The neco soundlab is still on low gain as use it mostly with the dt1350's. So does the auto gain of the m2 work on the line out?
So very happy bought the Aune M2.
Line out on M2 is a fix level (non adjustable) the same level as maxed out vol on HO and it is very powerful. In terms of quality I didn't hear any different between HO vs LO you can basically use either one or both at the same time.
Anyone know if there was an update recently? It's still not recognizing all my files.
Can you elaborate more, did you use 200 GB SD card ?
The latest FW I could find is 1.21
