Aune M2 | AK4490 Dac | Class A amp | Dual Crystek USA Clocks |
Mar 21, 2016 at 1:21 PM Post #391 of 823
lafeuill
Paris, France
Well, if you have 32GB of space available, there has to be a 32GB microsd card already in the M2 -> check on the right side ^^
Again, the M2 does not have internal memory, just an sd slot.
Mar 21, 2016 at 1:24 PM Post #393 of 823
zibra
Ok sorry for noob questions. I pressed it to ligt before but now manager to take it out. Sorry for stupidity.
Is it normal th​at M2 comes wit 32GB card or I received bonus?
Mar 21, 2016 at 1:41 PM Post #394 of 823
lafeuill
Paris, France
Bonus!
Despite its non-user friendly shortcomings - especially the lack of gapless play for everything that's not cue with single flac file - I like it very much.
Mar 22, 2016 at 8:39 PM Post #395 of 823
ExpiredLabel
http://www.head-fi.org/products/aune-m2-32bit-dsd-portable-music-player/reviews/15556
Throwing my first review up! Please share impressions
Mar 24, 2016 at 4:43 PM Post #397 of 823
ExpiredLabel
Oh man, yea upgrade now. You can find the firmware on Aune's main site. Its on the top I believe labeled global support and from there you can select the M2 and select the latest firmware (1.22).
Mar 24, 2016 at 5:12 PM Post #399 of 823
ExpiredLabel
Oh, so once you get the .dat file. Put it in the Main/root folder of the sd card. Once loaded, turn on the device. Go to settings and update. It will restart and load up from there
Mar 24, 2016 at 5:23 PM Post #401 of 823
ExpiredLabel
Oh yea, standard version is no slouch either. Cheers!
Mar 25, 2016 at 1:13 AM Post #403 of 823
ExpiredLabel
Should be closer to the 3.75-4 hr mark with what im getting, however instead of using the charger provided. I took a chance and decided to use my nokia charger. I have no idea what it is specifically about nokia but they make excellent chargers. So i'll use that if when I get to work and realize I'll need it later for the ride home. I typically charge mine at night when I go to sleep with a power bank that auto configures itself to the right current and will auto shut off when finished. I do that since I personally wont leave anything meant with purpose (aka my player) left plugged in well after charging as that will ultimately down cycle the battery and basically blow it sooner than it would have if you made sure to take it off the outlet.
My two cents, other might have more input. As for what type I believe its a 3500mah
If you have any questions about specs, my review covers that just so you know all your getting
Mar 25, 2016 at 1:33 AM Post #404 of 823
Merlin1975
Battery capacity I know, I'm interested in the manufacturer. Has anyone analyzed the player, where you can download or view the instructions for its dismantling, whether it will be possible to replace the battery yourself at home?
Mar 25, 2016 at 1:35 AM Post #405 of 823
ExpiredLabel
Oh I see. Sorry, as far as I come across in their very own DIY forums, none have tried it seems. Or rather, I should say at the very least they haven't bothered to share.
If you work out something please be sure to share, I wouldn't mind getting at least another hour if possible out of it.
