32bit 48khz Float song isn't being playback properly on Aune M1s at all........well there is a very loud distortion noise when the file was playback....I hope that this problem can be fixed.
Aune M1s Impressions & Discussion Thread (Aune's newest hi-res DAP with ESS9018KM + 2.5mm Balanced Out)
- Thread starter nmatheis
Ang Probinsyano
- May 1, 2017
anyone have tried grado sr80e with the aune m1s?
Hey does anyone here know Chinese?
http://blog.sina.cn/dpool/blog/s/blog_60c1aacb0102x2jo.html
Apparently the Aune M1S has a
Accusilicon AS318-B Series Professional Audiophile Crystal Oscillator. Pretty neat stuff the PDF file has on accusilicon.
rr12267
Here is the google translation of that URL
https://translate.google.com/transl...na.cn/dpool/blog/s/blog_60c1aacb0102x2jo.html
Aha! I guess this will do for now!Here is the google translation of that URL
https://translate.google.com/translate?hl=en&sl=auto&tl=en&u=http://blog.sina.cn/dpool/blog/s/blog_60c1aacb0102x2jo.html
Thanks!
Also I have to say Aune went above and beyond for me.
Candy was really helpful in checking the agent and shipping from Hong kong via dhl. Dhl to my place! I also got 3 free cases! Blue red and grey silicone cases.
I screwed up a bit applying screen protectors. There is a little bit of dust with a line of air bubbles on bottom of screen protector.
Here is a picture of da Aune box.
Anyone know if a Dignis leather case is available or in the works?
Also, waiting on the firmware to fix the loud pop sound inbetween DSD tracks - quite annoying.
hey has anyone gotten Aune to alphabetize their folders in folder view.
I have artists in random alphabetical order. But it looks fine when I load up SD card.
I'm using Fat32 formatted with Aune's guitformat from their website.
there is that pop sound, and some random stuttering (rarely) for only 4 seconds before it disappears.
I noticed that on an electronic song, I thought it sounded like a DJ using turntable to cut audio as an effect lol.
Hi, I noticed that the folders would appear in alphabetic view if i divide them in small group( A to F, G to P, etc...) If all in one big folder, files would be in "order of created time"hey has anyone gotten Aune to alphabetize their folders in folder view.
Hope that helps.
Thanks when I get home I will do that.Hi, I noticed that the folders would appear in alphabetic view if i divide them in small group( A to F, G to P, etc...) If all in one big folder, files would be in "order of created time"
Hope that helps.
Currently I have them all dumped into a Music folder. I will try out A-F method
xLoud
- Nov 29, 2015
How does it sound compared to Fiio X5 2nd gen?
Has anyone tried comparing a relatively new M1s, and a used (> 50 hours) M1s in terms of sound? I'd like to confirm whether if the differences I'm hearing with mine (> 100 hours) is due to memory fallibility, or burn-in effect.
Skullophile
- Dec 18, 2012
I had an X5 1st gen which was said to sound the same as the v2 and compared them to the M1s before I sold the X5.How does it sound compared to Fiio X5 2nd gen?
The M1s was more transparent, cooler, airer and doesnt do funny things to the stage. Sometimes the X5 could sound like you're listening in a hallway.
If you're running Ety's or cool iems the Fiio would be a better choice for the added warmth, apart from that it's M1s all the way.
- Dec 30, 2013
Hope that helps.
Ahh, that's prolly why I've never noticed funny filename sorting...
