alex5908
Will I be able to come back to my previous firmware?
Yes,Will I be able to come back to my previous firmware?
Hi,The player does not start. I thought that the charging would help but it did not.
What shall I do to revive the player?
Holding for 20 seconds does not help. Holding a reset and power button do not help either.
I have not changed the firmware.Did you follow the instructions correctly?
Ah, ok....I have not changed the firmware.
Light as a featherHas anyone got the dimensions of this player?
I’m curious how thick it is in particular but would be also interested to know the width, height and weight also.
Thanks
Tried all the available firmwares (1.65, 1.7, 1.78). Same issues@AuneAudio need your help
Hello! I am trying to update the firmware on Aune m1p. I formatted the memory card to the correct format and deleted everything from it except the firmware file. When I try to update the firmware I get an error "update.dat error(4)" or "update.dat error(2)". What could be the reason and what can I do?
Here are Aune's instructions for updating fw:Tried all the available firmwares (1.65, 1.7, 1.78). Same issues
Yep, did exactly via instructionHere are Aune's instructions for updating fw:
How to update:
1. Copy the update.dat file to the root directory of an exFAT microSD card, and insert the card into the M1p;
2. Select Settings - Upgrade System
3. Follow the prompts to complete the update.
