Aune M1P
Jun 14, 2024 at 1:25 AM Post #496 of 593
@AuneAudio - I am sorry, for me the scanning is a big problem. In my case it renders the device useless.
I took the M1p to a trip for 30 days and was hoping to use it to play music for me. But now it does not play anything it anymore, at least most of the time.
I have a Samsung EVO SD card with 512 GB, almost full, exFAT. The M1p was playing fine with that until some days ago. Now when I start it, the "scanning SD card" appears, the progress goes to 10%, sometimes 20% or even 40% - then it stops, the logo shows up and then "No Device". And then the process repeats. Yesterday, suddenly, it went through and actually played. Until I switched it off. Now I cannot get it to play.
I checked the SD card with chkdsk on Windows. No problems were detected. I also did not add anything to the SD card. The problem just suddenly appeared. The device was in a case all the time.
I did not see any information why this scanning is actually required. With most devices it is possible to play simply from the directory structure. Why is it different here?
Without scanning you could solve the issue with overlong filenames, and also do alpha-nummerical sorting within directories. (simply convert consecutive decimal numbers into a character of the value 0..$FFFF when doing a compare) and support M3U playlists. This would make the effort worthwhile. You can also reduce the startup time to the few seconds advertised on the website.
I am still not home, I can post a video of the start-scanning process in 2 weeks, if this helps to find the issue.
I also have the same problem vith Samsung evo 512gb,but on Qls qa 361.Sometimes my dap shows me “No music”,but after replacing Sd card(sometimes it needs 2 or 3 times) it works.
Jul 24, 2024 at 9:35 PM Post #498 of 593
@AuneAudio Any news on letting us create or play some playlists? M3U for example?
One more question. Can I charge the device while listening to music?
Hi, at the moment we don't have a plan for M3U:)
And it's not recommended to charge the M1p while listening to music.
aune For music we design. Stay updated on aune at their sponsor profile on Head-Fi.
https://www.facebook.com/auneaudioofficial https://twitter.com/auneaudio https://www.instagram.com/auneaudio http://www.auneaudio.com sales@auneaudio.com
Sep 3, 2024 at 9:34 AM Post #501 of 593
i just get to use my M1P, but i use the card that is provided and it has pre loaded some song, then i just add in my songs. now i cant load anything the Orbituary thing appears!
If i would like to update firmware do i need a clean micro SD card to update? i dont have a another micro SD card
Sep 3, 2024 at 10:09 AM Post #502 of 593
Just received the Aune MP1 slapped in a 1tb card super fast start up and all albums recognised now playing music and it sounds amazing very happy
Sep 10, 2024 at 10:16 AM Post #503 of 593
Del
Sep 10, 2024 at 10:17 AM Post #504 of 593
Sep 10, 2024 at 10:27 AM Post #505 of 593
Is it feasible to downgrade from fw. 1.078?
Sep 11, 2024 at 4:44 AM Post #506 of 593
I have the firmware 1.078/0.1/0.0 and no problems since I switched from a Samsung SD card to a Kingston SD card (Kingston Canvas Select Plus microSD, SDCS2/512GB Class 10). Now it works. The device appears to have problems with some cards, maybe if they draw too much power during scanning files since the problems shows up really randomly.
Unlike one would expect, this device scanns all file names and puts them into a memory table at start up. Why? - I don't know. The concept has basically only disadvantages.
Sep 12, 2024 at 5:10 AM Post #507 of 593
i'm also very happy with a 1.078
play-pause works with screen off and my sandisk 512g card also works without any issues.
it's definitely an interesting design choice to have the device fully power down, clearing out any persisting memory. When the device is off - it is off. the battery drain is pretty much zero. However this thing does sound 'better' to my ears than any other portable device i've tried.
Sep 12, 2024 at 6:00 AM Post #508 of 593
Sep 13, 2024 at 10:21 AM Post #509 of 593
Sep 13, 2024 at 10:25 AM Post #510 of 593
Thank you very much for the link.
The first link does not have any FW. Was it removed by Aune?
Will I be able to come back to my previous firmware? Asking it just in case.
Hum, you should be able to download a zip file with the last FW :)
