islubio
- Jun 27, 2010
that will be fun
Looks like you are gonna "tune" the crap out of the T800 haha
that will be fun
i am not sure about the size, so i bought two different sizes just in case, also i have Etymotic ER4S and i want to have some spare dampers for themLooks like you are gonna "tune" the **** out of the T800 haha
for all owners of T800 that wait for knowles dampers, be aware that with added damper the soundstage will be HUGE, wide like the back of Ronni Coleman in his prime
the filters are reducing the upper mids and lower treble, the upper treble is almost untouched, that is the reason for the soundstage size increase, less upper mids, same upper treble = bigger stage sizeHave u tried any filters that will just affect the sound stage and not reduce the treble?
I'll give it a try and see how it sounds stock. If I find it a bit much I'll try the spiral dots. Since I'm ordering them from AliEx it comes with a copper cable so I'll try that also. My last option will be the filters. Hopefully all goes wellI have everything in stock for now, but only because filters didn't arrive yet
The stock cable looks and feels fine to me, i will try to replace it only if changing filters doesn't help.
With spiral dots and stock cable/filters i hear no sibilance, still the sound often is too "intense" and bright for me.
Yeah I saw that they are shipping via DHL which is awesome . Could you please take a photo of the copper cable that came with the T800? Hows the quality of it?Oh man so sorry. I shared it from the mobile app.
And yes it's the AUDIOSENSE Official Store.
T800 will ship from them from Hong Kong via DHL. Very good customer service
..now im scared of using it without the filters, ordered 20 3,7mm and 20 4,0 mm ones. Am i being paranoid or should I avoid using them until the filters arrive? And do you need to clean the nozzle before inserting the filters? Like with a airduster or will that cause damage?Regardless of whether you use any additional dampers or not, you may want to consider protecting the stock white damper with stainless nozzle mesh.
Why? Well, the stock nozzle is totally open, and the stock white damper can’t be replaced or accessed. Once it’s damaged or clogged, it’s game over for your $300 T800.
Stainless mesh is transparent sound-wise, and at a cost of a few pennies each it is very cheap insurance.
Another advantage is that if you use additional dampers, it prevents them from ever falling out (into your ear, losing them on the ground, etc).
The correct size is 3.7mm, but 4mm will work in a pinch if that’s all you have.
Which jvc spiral dots do you Guys use atm.. There are like 5 versions of it which is confusing.. i mean the size? Shall i order the L size or M? I use wide bore tips and KZ ate foam tips on it atm.. Which shall i order can anyone give me advice?
@blomman77 already did it, measurements from himBtw i would be usefull if somebody makes a list what all filters do for future usage and to tweak for personal preference
