Dear community,
So I jumped on the T800-train two days ago, confident that it would pair at least decently with my LG V40. However since these gems yesterday got sent on their way towards me and my beloved LG, I decided to delve a little more into pleasant anticipation and made my way through almost the whole thread - and had to learn that it takes quite a weird bunch of tricks to reach a satisfying output with the pairing.. Here's my story:
While originally I thought I just quickly buy the heaven-sent T800s quasi-endgamers and finally find peace, I meanwhile have ordered additionally, JUST SO I CAN USE THEM TO AT LEAST HALF THEIR POTENTIAL:
- Several Knowles dampers here in Germany
- Since not available here, Knowles damper installation tool from China
- 3,7 mm mesh
- Replacement cable from Xiaofan
Ok, now good to go, I thought, now I can just relax, I thought, and wait a few weeks for all the stuff to arrive, and then to finally just put it together and then to relax and just enjoy the sound, I thought. Then I read about the compatability issues with the LG V-series.
Ok, I thought, not a problem, keep your cool, just a few more happy little accidents - chill out and follow the requirements:
- Breathe
- Ignore the KZ-starline-tip-finetuning-modification-suggestions, as well as the ones advising to drill holes into the shell or cut into rubber tips - focus on the majorly required modifications in order to enjoy the T800s with your super-simple-easy-to-go-final-solution-audiophile-phone:
- Buy Y-splitter
- Buy a separate set of earphones just to trick the LG to go into impedance mode (VE Monks)
- Buy an app in order so you can check if LG got into high-impedance-mode
- Breathe again, clean up the mess, joyfully look forward to the T800 arriving!
Ok, I thought, it's not that long-winded and cumbersome actually, see, you're gonna have a blast with these.... THINGS! Even if the impedance-trickery won't work with the splitter and the other earphones, you can, as suggested by several others, just buy an impedance adapter, quickly sent from China, you wouldn't even have needed other headphones, stupid! Just follow this simple setup described on Amazon:
"Step 1. Don't plug anything into the phone. Connect your headphones to either Faael adapter then connect your 3.5mm aux cable/adapter (a decent one that doesn't degrade your audio quality). Connect everything first! The order of how you connect them doesn't matter at this point!
Step 2. Plug the aux cable chain into the LG phone. Wait five to ten seconds. Or better yet pay a dollar for the LG Hi-Fi status app in the Google Play store to see the status of the phone. 50ohm will pop up in notifications with the app.
Step 3. While keeping the aux adapter/cable plugged into the phone, unplug the Faael adapter that's connected to your headphones first. Remove the faael adapter completely from the chain. It will degrade your audio. Then plug in your headphones into the aux adapter/cable and enjoy more power!"
So again, just breathe, ignore the following consumer feedback according to which it did NOT work,
and finally just happily (!) look forward to the neat and handy setup you soon will (in each occasion after the 3-step-program and in case that it actually works) enjoy as your on-the-go audiophile endgame:
(special thanks to "papa253")
Ok, it's all good, I thought, just chill now, all will be just F-I-N-E, why not just see it on a positive note - pick something! Go with Joseph! Why not Jesus! See the positive! Look what God wanted you to see: The whole force-into-high-impedance-mode-setup is so intolerably and grotesquely quirky and labourious, and people then anyway lament the quality in comparison with real DAPs, so why not use this mess to
FULL-SYNCRO-POWER
and SIMPLY add an amp to the m'fing phone? Hmm, stupid? Just glue it on the back or something, dude, one cable in, one out - as SIMPLE and handy as a Nokia 3210 dude! Just for instance, as a companion in misfortune, assigned and proud V40-and-T800-owner as well, happily suggested not too long ago in this little thread, why not just buy the "E1DA 9038S Gen 2 USB DAC Headphone Amp and Cables", from Aliexpress, it reportedly sounded phenomenal! Hmm, PERSPICIOUS SOLUTION, and only an additional 80 bucks, after all the stress, not willing to fight over that now, let's just buy this shiznit and then FINALLY not only having these PUNCHING-WAAAAY-OVER-THEIR-PRICE-ENDGAME-GEMS, but hey, a really solid amp as well, further contributing to all the love-making the T800s will devotedly spoil my ears and synapses with. Just a handy solution, see, now just breathe DEEPLY, get your act together and just m'fing BUY these and it's OVER!
Okeydokey, quick, let's smoothly surf to Aliexpress and finalize this excursion, by the powers of "E1DA 9038S Gen 2 USB DAC Headphone Amp and Cables", bring it to the glorious ending it deserves! Oh look, the reviews are not only promising, these are AMAZING! There is only a minor issue here, the amp feeds on the battery like the headphone industry on the hopeless asymptotic perfectionism, inner restlessness, let's just say - spiritual emptiness of the so called audiophile community - so that one needs a separate powerbank to feed the MONSTER! The genius-level on-the-go setup then looks as follows:
Beautiful isn't it. Love this hobby - cheers
