mbwilson111
- Oct 13, 2016
Tight into the cups?I am using the really thin cable for my iPad and MacBook Pro. I came from using the Audeze isine 20 but return it because it was uncomfortable. I think I have it tight.
So you have the original Nighthawk like me. There was a problem with the thicker long cable breaking for many people but the thin one should be ok. The newer Carbon Nighthawk comes with only one thick short rubbery cable. If you want something else later you can find suitable inexpensive replacement cables by searching ebay for Sennheiser HD 700 or (the same quality for less money search for HD 497 or HD 212). I am using one listed ofr the 497 that came to me from China (ebay).
I have no idea what kind of bass you should expect from an iPad or a MacBook. Hopefully someone else can advise you. No matter what your source the bass should just be nice and accurate (enough body where body exists). At least that is my perception. It won't and should not be Beats like thumping. I am sure someone with come along you can help you more.
