Joeybgood
does anyone know whether AQ(or ANY cable manufacturer) will be offering balanced cables for the NightHawk?
Sent you a PM.
Though the NightHawk cable is already fully balanced, it is terminated with a 3.5mm phone plug in its stock configuration.
We are working on a version with balanced termination, but to meet AQ standards, we must design the 4pin XLR from the ground-->up. We will release this cable as soon as possible.
If you own NightHawk and want a balanced cable in the meantime, send an email to info@audioquest.com
Do you guys have plans on releasing more affordable headphones? Those Nighthawks look killer though...
Have you guys ever considered using some sort of ceramics for the cabinet pieces? ( I would imagine some sort of rubber coated sprayed on the insides to help tone down acoustic resonance.) It would I imagine be cheaper, extremely renewable and easier to manufacture.
Yes, we do have plans to introduce headphones that are more affordable than NightHawk. We also plan to intro headphones that are more expensive (these won't be for a while though—lots of research needed).
In the past I have built prototypes using ceramics, but they typically end up being twice as heavy as other alternatives, so that seems like a dead-end since minimizing weight in a headphone is so crucial in my opinion. The resonances are also a concern as you mention.
NightHawk's liquid wood cups were a serious challenge to develop. But now that we have refined the process and material over about 1.5 years, our cups are much easier to manufacture than would be from ceramics. Also, ceramics are limited with regard to dimensional stability, fine details, and wall thickness. For instance, we would not have been able to integrate stiffening ribs with ceramics like we were able to do with liquid wood. Further, liquid wood beats out ceramics for sustainability since we are essentially reclaiming the raw material from an industry where it would otherwise be wasted by incineration. Ceramics would probably be cheaper...but not significantly so.
Your idea about using rubber to coat an enclosure for resonance damping is spot on. That's why we do this on the internal surfaces of NightHawk's earcups. This makes liquid wood (already a self-damped material) that much better at preventing resonance.
Here you see the integral support ribs (inside NightHawk's earcups) enabled by liquid wood along with our unpigmented (clear) rubber coating, which has viscoelastic damping properties. Kind of hard to see the coating without knowing what liquid wood looks like uncoated. For comparison, you can sort of see the lighter-colored ridges that are uncoated in the bottom left and right corners.
I had the pleasure to test these today for a few minutes.
They are very comfortable and they used some cool stuff in order to make it so.
Which cans can you compare the comfort to?
How was the sound?
Wow. I just had a chance to listen to the Nighthawk, and the last thing I thought of was that it was too bright. Quite the opposite actually.
I have no idea what I'm talking about. My limited English makes it hard for me to describe sound. I think the EL-8 sounded a bit more dark, deep and warm.
