Solduios
- Jul 29, 2012
One of our guys visited BBR today to check out their demo pair. They were indeed using the backup cable and not the official AQ cable.
We also confirmed that the headphones were in good condition in terms of sensitivity on an iPhone 6.
I did some tests today with my iPhone 6 in my lab inside the iso chamber with my friend, KEMAR, measuring average A-weighted dBSPL output over 60 seconds at various volume levels. iOS has 16 volume ticks; I started at 8 and worked my way up.
I tested a lossless copy of the same Billy Joel Album using the last 60 seconds of one of my favs..."Big Shot."
I also tested full scale white noise.
Source Material DR vol 08/16 vol 10/16 vol 12/16 vol 14/16 vol 16/16 Billy Joel - Big Shot DR9 78.8 dBA 87.1 dBA 94.6 dBA 101.5 dBA 108.1 dBA Full Scale White Noise n/a 87.1 dBA 95.3 dBA 102.7 dBA 109.5 dBA 116.1 dBA
As long as everything was working properly during your demo, then you would have been exposing your ears to an estimated 108dBA on average while listening to the louder passages of Billy Joel at full volume.
At this level, permanent hearing damage can occur after only ~5 minutes of listening. The safe zone is really 85dBA and below, so with music mastered like the Billy Joel album, a volume level of about 11/16 ticks (69%) and below is appropriate for an iPhone 6 with NightHawk.
All this is to highlight two points:
(1) An iPhone is more than capable of driving NightHawk even to levels that could damage your hearing, so...
(2) Please, please, please be careful with your hearing out there, folks. Here's an excerpt from NightHawk's printed manual:
For example, if you were to safely listen to this entire 2-disc Billy Joel album (~2 hours) via iPhone 6, the volume should be set no higher than 11/16 ticks.
Could it be the resistance from the back up cable vs the better offical cable? Or maybe his iphone jack is a bit worn and the conncetion was not 100%?
Also doesnt iphone warn you past a certian amount of clicks that it could dmg your hearing with headphones?
