^Thanks for letting me check these out BTW I really appreciate it!!!
So I have
@SomeGuyDude's Nighthawks here.
Quick impressions before a full comparison to the Vali which seem to share alot of the same pros and cons.
Pros:
- Capable of being very clear with eq.
- Very clean and refined sound. This type of refinement is found usually at a much higher price. Much Much higher.
- Liguid like texture without extra decay
- Articulation/microdynamics and details are great
- Extremely well thought out build
- VERY comfortable
- Bass doesn't sound distorted and reaches very low and gives oodles of texture. EXCELLENT BASS quality. Playing a lot of my hip hop reveals this. Probably better bass quality than the Vali it seems so far just less responsive and slightly less weighty though deeper.
Cons:
- Most of the cons, if not all are tied to its frequency response. Some headphones have technical issues that hinder it but here it seems
alll about balance.
- There is a very thick veil around the region responsible for playing muddiness 200-500hz. It makes it sound like there is negative sound pressure over the midrange, like its clouded
- There is also a lack of presence in the midrange proper as well as the upper mids that need to be aggressively boosted. I find the Air to be okay even though it could use a little more air its not as rolled of as the Vali on either end but the strong peak(edit, not strong but a little odd compared to the rest of the balance) in the treble, while not harsh gives a welcome respite from the cloudiness in the midrange.
- Its not really dynamic sounding. i could wish for a more aggressively punchy response but I see this has its place.
- Soundstage... ummm I think it is okay. I don't feel smothered but it could use some more space. My modded Pioneer has a bigger soundstage... by a lot.
