SomeGuyDude
- Jun 24, 2012
TBH for the hawks you don't need anything like that. Those giant amps are massive overkill.
Remember what an amplifier does: amplifies the signal fed into it. That's all. That is the entirety of its job. It takes the signal out of the DAC and makes it more amplified in order to provide enough power to the headphones. Any sonic alteration it gives isn't due to its quality, it's due to its coloring. As long as the power coming out of it is clean (not distorted), you're getting zero benefits from spending $5000 versus $100.
This is especially true with the NH since they're easy to drive to begin with. They don't need much extra juice so if you're putting those giant amplifiers on them it's like sticking a V8 engine on a bicycle.
