splaz
- Nov 18, 2005
Are the resistors you chose a no-no...
They'd work, I mean different aim but high precision resistors are often wirewound. Difference being these are for power applications not precision.
I have never done a comparison between resistor construction types.
Why not try it for yourself ? Maybe do a blind test or whatever you're happy with... or just use them and if they sound good to you then who's to argue with your ears ?
If they're +-5% though I'd try and match them or pick out the closest if you have a meter.
I'd personally be more inclined to use a high power metal or carbon film, purely because I wouldn't be bothered trying the wirewound and I'd have this weird paranoia that it could sound better with different resistors.
I just use generic 60/40 solder, I'd get 63/37 if I could but it's been hard for me to find where I am.
Wires, I can get trade prices on some wire, but typically not stuff like canare/belden. I personally don't use fancy stuff, just whatever suits the job in the right gauge, almost always plain old copper.
Connectors, depends again what for. I quite like Amphenol and Neutrik connectors.
Personally, the only things I worry about sourcing 'audiophile' parts for are ICs like op-amps and electrolytic capacitors, they're typically the main thing I get sourced from overseas.
Originally Posted by Navyblue /img/forum/go_quote.gif It's not that I got to have boutique stuffs. Just that I'm new in this and I don't know how much would all these affect the final outcome. Ok, all these are subjective but I don't want to be doing things that are obviously wrong. I think I know where to get good plugs (not sure if they really are, but they looked shiny) in various forms locally. I might be able to avoid adding switches and LED. But I still have the followings - resistors (are those above a no no to use?) - solder (it comes with the soldering iron, do they make a lot of difference with Carda stuffs?) - wires (what should I get, expensive speaker cable from audio shops? or just get it of hardware shop?) - plugs (get the shiniest I could find? |
