Audiobyte Hydra Stack: Hydra.Vox + Hydra.Hub + Hydra Zap
Aug 8, 2023 at 2:39 AM Post #738 of 1,017
w/ my ears: USB (from PC) < LAN < SPDIF/AES (w/ SU6 DDC)
w/ FMC (Fiber Media Converter) Mod on LAN its nearly LAN = SPDIF/AES (w/ SU6 DDC).
However chose LAN due to convenience.
Aug 8, 2023 at 5:37 AM Post #740 of 1,017
Another (same thing on what I hear or what I remember):
[ USB (from PC) -> SU6 DDC (via I2S/HDMI) -> ZAP ] nearly = [ SU6 DDC (via SPDIF/AES) -> HUB ]
on supported files, no oversampling/format conversion on HUB.
Aug 8, 2023 at 8:56 PM Post #741 of 1,017
Mickey I'm not quite sure why I'm following or commenting on an Audiobyte thread, but I'm confident that the insertion of an Ifi LAN iSilencer after your clean FMC would satisfyingly elevate your LAN chain even further possibly beyond the SU6. As would vibration damping of the clean FMC, but to be fair you'd have to do same for SU6. 😉
Aug 9, 2023 at 2:00 AM Post #742 of 1,017
OK bro will try! But i have that kind of thing already with Delock 62619 two of them in a series.
Aug 9, 2023 at 9:55 PM Post #743 of 1,017
Yes! It is both a format converter and upsampler. This is done configuring the rate and output of its I2S:
I2S PCM Processing: Native (same as source), 352/384PCM, 705/768PCM, DSD256, DSD512
I2S DSD Processing: Native (same as source), , DSD256, DSD512, 352/384PCM, 705/768PCM
Haven't use HQPlayer for sometime now. Just let the HUB do its thing.
For example, what I like right now is all inputs are converted to 705/768PCM.
So here is an example of DSD256 source via UPnP (using BubbleUPnP on my NAS) converted to 705PCM -> to Vox (DAC) via I2S.
hi Mickey, in this way, the "DSD direct" in your VOX is set to on or off?
Aug 10, 2023 at 12:37 AM Post #744 of 1,017
Two years ago when we were fixing my relay issues with the HUB and Nicolae sent me the fixed FW, he said they had to reduce to DSD256 when DSD Direct is set to ON from the previous DSD512. What I have done UNTIL NOW is set DSD Direct to OFF and set attenuation/volume to 0. Haven't ask support if the current FW DSD Direct was set back to DSD512.
Aug 10, 2023 at 12:43 AM Post #745 of 1,017
hi Mickey, in this way, the "DSD direct" in your VOX is setto on or off?
thank you Mickey!
Aug 10, 2023 at 3:14 AM Post #746 of 1,017
What I prefer right now is to upsample everything to PCM 705/768. So DSD Direct OFF and Attenuation to 0.
Aug 10, 2023 at 6:02 AM Post #748 of 1,017
Maybe, we need to clarify this. And if its DSD256 or DSD512...
Aug 13, 2023 at 7:37 AM Post #749 of 1,017
I do have the Hub(3 set unit) my friend tried to give me a Naim Uniti Atom Headphone Edition, how can it work with my Hub? Is there any double feature? Meanwhile I’m using iMac as a Roon Core but not quite stable is Naim Uniti can instead my desktop or any recommendation? Thanks for all kind of advise.
Aug 13, 2023 at 9:33 AM Post #750 of 1,017
You can use Uniti as your UPnP Server (w/ USB drive attached) to your HUB.
If your HUB has the optional Analog XLR, Unit XLR Analog outs to HUB's XLR Analog ins.
If not, use Uniti in your bedroom/office, or you can give it to me.. 😜👍
