For those of you who have the PMx2 or have heard it a few times, which can does it remind you of most? I've heard it resembles the HD600/650. I've heard the 650 (not through a good amp though, only AudioQuest USB Dac/Amp unfortunately), never heard the HD600. Thanks.
I have both the PMx2 and the HD600. I just listened to them side by side on my system: JRiver -> Schiit Gumby -> Ragnarok -> balanced cable -> headphones. (I also have the Mimby/Vali 2 combo which work really well for so little money.)
While I can see the comparison between the two since I consider the HD600 fairly neutral, the PMx2 is significantly better.
The bass on the PMx2 goes lower and is cleaner and tighter, and more detailed.
The mids on the PMx2 are more natural sounding. I am not sure how to characterize it, but say on a piano recording or vocals, the PMx2 sounds more "real" in it's tonality.
Ont he high end, it's not dark at all. It's super detailed, but not elevated or harsh. It reminds me of the smoothness of electrostats, but not elevated or artificially boosted. For example, with my Stax 009's, I LOVE the high end for it's speed and smoothness, but it's clearly not what I would consider neutral. It's elevated. The PMx2 reminds me of that smooth, detailed sound, but neutral not exaggerated.
Can you tell I love my PMx2's? When evaluating any other piece of gear or software, I always use the PMx2 as a reference so I know that the headphones are giving me an accurate representation of the gear upstream in the chain. It's not adding to or coloring the sound.
The HD600's are amazing especially for the price, but the PMx2's are a big step up.
Hows the treble on the PMx2? I heard a modded PM2 (not the PMx2) through a cell phone and thought the treble was too laid back. Again, it was only through a phone, so it probably doesnt mean that much. I am dying to hear the PMx2 but cannot get to hear one yet. i'm using the Ether open right now. thinking about selling it for the PMx2. What amp do you use yours with? I have a tube amp right now.
While the PMx2 (and PM-2 for that matter) can be driven OK from a phone.), they sound much better through a better amp.
However, I have heard stock PM-2's and to me they sound nothing like the PMx2. If you couldn't see which headphones you had on, you would not believe they start off as the same headphone. The stock PM-2 is really dark to me. The PMx2 is not laid back. But if you prefer a more U shaped sound signature, then I could see the PMx2's not having the elevated highs that some people like.
Then when you're comparing someone else's modified PM-2's, you can't really assume that someone else's modifications will sound at all alike. I don't know what modifications were done to the pair you heard, but I would be surprised if they are as extensive as what Alex does to the PMx2's. The amount of work he does is crazy. He has a
30 minute video explaining what he does.
