Dinerenblanc
- Oct 20, 2014
The Auvio may be a little bigger, but they're the same general size.
I matched then up next to each other yesterday, they're the exact same size.
How is the fit with the IM50s? Would I be able to use them at the gym without the housing falling out of my ears?
Don't think anyone would be able to answer that with certainty as it depends largely on your ear shape.
I assume
I assume the IM70 is very similar but I only use mine for the gym out of all my iems. I find they have the most stable, least fiddly fit and the least cable noise for doing exercise. It helps that they're built so well .. both cable and housing are built like tanks.
H3 are super comfortable but certainly can't run with them. They're just not held in place secure enough for that sort of thing but IM70 I find for me fits really well and doesn't move around at all.
Just unboxed my very own pair of IM-70. Well all I can say is if it fits your ears, it shouldn't fall out during exercise.
hmm... hearing a lot of popping/static sound from mine though.
Is that while music is playing or not? I get that when music isn't playing and it has to do with the source and the sensitivity.
Wow... that certainly doesn't bear out in my experience. Listening to similar music though my MacBook sounds just fine. A file quality issue, maybe? Could you point out where they happen and in what songs? I'd like to see if it's a problem with the headphones in general or just your pair.
