Hooster
- Nov 4, 2010
less fatiguing, but not better sound right? Pretty sure the Clears will be more accurate.
"Better" is subjective. Is better something that is very detailed and in your face, or is better something that is fun and comfortable to listen to for many hours? It is really up to you. I am not using my headphones to mix and edit music so I will take the pair that is entertaining and comfortable over the superficially hyper detailed pair. To me that is better.
Also, are you sure the Clears are more "accurate"? Is it possible that this perceived accuracy is just an artefact of problems with the driver that will become fatiguing/annoying in the long run?
It is your money and your ears, so pick your choice...
https://www.audiosciencereview.com/forum/index.php?threads/focal-clear-review-headphone.18585/
"Misses are the overshoot between 600 and 1.6 Hz. The lower range of this from my speaker testing usually hides some detail in the music. There is a flat area as indicated by the arrow. Clearly, pun intended, the driver is doing something strange there. Group delay shows similar problem:"
"There was some detail lacking and some brightness that was bothersome. It created fair amount of "lispiness" with female vocals for example."
"Conclusions
The Focal Clear "out of box" (no EQ) response is closer to what we like to see so tonality is not too bad as is. Equalization can take its performance significantly higher but due to poorly designed drivers with too little headroom, this is not a practical path unless you keep volumes low. Without EQ is less of a problem but you would face some brightness and some lack of clarity. At these prices we better not have such compromises."
