johnjen
In my setup using dante, the elimination of any and all SMPS's was noticeable and cumulative.
And depending upon your budget, shorter ethernet cables and even using an optical link/break between the computer and the rednet device can help as well.
And the phrase 'the whole is greater then the sum of the parts' is a good analogy, but really just getting away from USB seems as important.
And for most folks 88.2/96KB sample rate is about optimal, if hi-res is your thing.
For me I run everything at 44.1, because the Schiit JggtB dac is 'tailored' to optimize that SR.
But since you've got a dante solution for $400, embellishing it with additional 'expensive' gear, (Mutec 3's, outboard clocks etc.) seems silly because they all are well over twice the cost of your entire implementation, and even the couple of tweaks mentioned may only make marginal improvements, depending upon the resolution of the rest of your system.
We have come to use the term REALNESS to describe the resultant SQ changes we hear from our dante systems.
And at least for me there is no going back.
JJ
JJ
