peteAllen
Sure
I had disabled SATA on the mobo leaving everything PCIe/CPU as explained.
For a simple comparison at your request, I enabled SATA and put in fb2k the "same" flac/track (Silver threads and golden needles from Fotheringay 2 - not the one on Youtube) on Optane on the one hand and on the SSD on the other (all LPS).
The Optane instance sounds better. It breathes. It has depth. The SSD instance is thinner - more like a transistor radio. Less subtle. Fewer layers to voice.
Just to be clear - Larry's smaller Optane cards are M.2/chipset hinged.
Thanks for prompting me. I had planned to check this anyway. I can relax now![]()
So having sata disabled is the key? If you have it using Optane and no ssd or anything on sata, but still have sata enabled, then does it still sound inferior?
Not sure if it's feasible for me - I use an old small factor fanless pc - I think I'd need to upgrade to a 7th gen small factor mobo, buy an optane for the OS, and use my 2tb music ssd somehow (it's almost full!)
