Audio-gd USB-32 Firmware, Drivers, and Feedback Thread
Jan 24, 2014 at 6:52 PM Post #166 of 646
Getting some crackling with ASIO using JRiver 17 on V2. Kernal Streaming seems solid.
Edit- after a pause the music played back sped up like the turn-table was cranked. Very strange.
This might be a USB thing. Try using another port, or see the bottom portion of this guide to select a USB port that is not being shared with other USB devices.
Jan 25, 2014 at 4:08 PM Post #167 of 646
2014V2 firmware flashed and 192k playback is back. SQ still great!
Jan 26, 2014 at 8:10 AM Post #168 of 646
same problem here: no 24/192 support after FW-upgrade and driver update. ASIO still not working for USB. Listening with Win7-JRiver 19- nfb15.32. Just read about the V2-upgrade, let's hope it works.
Jan 26, 2014 at 12:45 PM Post #169 of 646
24/192 is working now. Still no ASIO in JRiver. VIA ASIO panel doesn't work anymore ("Enumerate filter failed").
General impression of FW 2014 over 2013: works more smoothly, no clicks etc. any more (consumes less CPU ressources), KS and WASAPI without problem. Windows mixer disabled (I wondered why it had been active before in KS and WASAPI).
Good Job!
Stephan
Jan 31, 2014 at 8:42 PM Post #175 of 646
I upgraded my Reference 5.32 firmware and driver with 2014 version. I also have issue with 16/192 and 24/192, no sound coming out. Beside that, sounds fine. This is on Windows 7.
Feb 1, 2014 at 3:01 AM Post #176 of 646
Have you tried 2014V2? That solved the problem for me. The new version has replaced the old one on the audio gd homepage. (Don't be confused: the firmware appears as "bin" file instead of "dfu", but that's fine.)
Feb 1, 2014 at 3:48 AM Post #177 of 646
I've tried the FW/Driver 2014 V2, I prefer the previous version, the newer sound cleaner, brighter but harsh.
I don't know if I will swap to previous version, I will try with warmer amp because I like the increased soundstage and clarity, extended treble that were a but muted on extremity.
Feb 1, 2014 at 9:31 AM Post #179 of 646
This morning pulled the Master 7 to the workbench for mods and upgraded the Ref 5.32 to 2014 V2 firmware.  No problem with 192kHz playback and also using Win 7 64.   The Ref. 5.32 never sounded better!   Sure you have the latest V2 version of the firmware?
Feb 1, 2014 at 11:07 AM Post #180 of 646
Looks like I didn't get the V2; I've re-downloaded and I'll re-apply firmware and driver. Thanks.
