Yes supposedly it will. The issue is there is a bug with Foobar and Windows and higher rez listening on your PC. This doesn't happen on all PCs. Just out of curiosity what PC do you have?But wouldn't that lower resolution?
Ive heard that most people can't differentiate over 44khz cd quality but if my system can handle it, I want to utilize it and get the best results possible.
That bring said, problem did not reappear after I lowered it to 96Khz. Still sounds glorious to my 40 odd year old ears.
You could upgrade to JRiver or Audirvana Plus and the problem should be solved.
