normanl
- Aug 27, 2010
Has anyone listened to both R-28 and Ares and how they are compared to each other?
Congrats! You’d swear Audeze voiced their headphones on this amp. Try out NOS 3, my favorite setting by far.
Yes I burned mine in for 500 hours before giving it a proper listen, but it was excellent out the box. My NOS 3 was broken (clipping and distortion at low volume levels) but the new fw (smooth) fixed that and now it’s superb. Put it this way, I’m not sure what ingredients Kingwa used for the new fw but anything that gives the Elear this much soundstage (width and depth) should be widely applauded! Good luck with yours!It's been only a few hours since the unit has been on. As per my experience with R2R DACs (R2R-11, Modi multibit), think I should give it at least 48 hours non stop power to stabilize.
(the Modi multibit was so bad that I had channel imbalance for 3 days after I switched off the unit when on holidays).
That being said, I did try the jumper thingy, cause I was super curious. The NOS 3 (S1 ON, S4 ON) seemed a lil weak to me. (Perhaps not burnt in enough or wrong jumpers?)
We really should get some proper chart to spell out exactly what's going on with what jumper, etc.
Sounds like your PC can't handle the processing requirements of such high-res files?Does anyone have issues with Foobar freezing up?
Unknown error code : 0x88880001
I checked online, and it said try changing output sample rate to a lower Hz.
Mine was on 32bit 384Khz and froze (windows bing and clicks were normal, as were media player, just Foobar)
and once I changed to a lower rate, it worked... till it didn't even with 352Khz, so lowered it to 192Khz and now
it seems fine.
Very strange!
Maybe that’s not the issue thenDude, I'm using a 3 month old $2k+ system!
Welcome to the club my friend. You are going to love the R-28 even more as you let it burn in. I had a similar experience where my R-28 sounded terrible at first but I left it on for a few days and it sounded fabulous afterwords. I don't turn it off now.
Try changing the R-28s default playback to something else beside the default. I think it is at 16 bit, 48000 Hz. Try 16 bit, 44100 Hz (CD Quality). You can do this in the control panel under sound.Does anyone have issues with Foobar freezing up?
it seems fine.
Very strange!
