Audio-gd NFB-28
Jan 6, 2015 at 1:49 PM Post #646 of 2,104
I had no issues with drivers on my NFB-15.32 either.  Just make sure you install the right one (duh) and it works perfectly fine.
Also note that you only need the drivers for USB.  If you use optical, no drivers needed.
Jan 6, 2015 at 2:11 PM Post #647 of 2,104
Ok, thanks. Normally I don't need drivers on my Mac, but I'll be using this at work using Windows and my current Schiit gear doesn't need drivers unless I'm playing hi-res audio (which I'm not).
Jan 13, 2015 at 1:59 AM Post #648 of 2,104
Can someone help me out with my NFB-28? I'm on Windows 8.1 x64. I think I've installed the drivers correctly, however whenever I installed them, it said driver version 1.2 (Is that the latest version?) When I select playback device it says SPDIF Interface. I thought SPDIF was only the optical chord.
I can get audio through Foobar2000 and Windows system sounds, but that's all. Is there any way to hear audio from Spotify or Chrome, Firefox?
Edit: I think I've found my issue, I had the default sample rate set too high. I changed it from 2 channel, 32 bit, 384000Hz to 2 channel, 32 bit, 192000Hz.
Jan 13, 2015 at 10:10 AM Post #649 of 2,104
You also may have to go to your playback devices and set it to the default device.
Jan 14, 2015 at 9:34 AM Post #650 of 2,104
I believe you need to have the driver from audio gd I stalled that correlates with when your device was built. But the newer on May work as well I have never tested it on my audio gd stuff.
Aside from that yeah - I believe having your whole system go will have to be at 192 - also what jodgey said - sticking with same USB port gettin it locked in as that default device when the unit is on.
ZMFheadphones ZMF headphones hand-crafts wood headphones in Chicago, USA with special attention to exceptional sound and craftsmanship. Stay updated on ZMFheadphones at their sponsor profile on Head-Fi.
https://www.facebook.com/ZMFheadphones https://twitter.com/ZMFheadphones https://www.instagram.com/zmfheadphones/?hl=en http://www.zmfheadphones.com/zmf-originals/ contactzmf@gmail.com
Jan 14, 2015 at 9:55 AM Post #651 of 2,104
Having a tough time deciding between a used ViolectricV200 (plus existing Wyrd + Modi) and an NFB-28 or NFB-10.33. There's something about German engineering and the black background and solid bottom end of the Violectric that keeps calling.
Jan 14, 2015 at 11:26 AM Post #653 of 2,104
Audio-GD devices are pretty heavily biased into class A.  Be sure to give it a few hours to warm up and settle before listening too critically.
Jan 14, 2015 at 11:52 AM Post #654 of 2,104
In the Schiit Story thread, Mike Moffat said he leaves all his Schiit gear on 24/7. They've been on since the last power outage 4 months ago, lol. Of course, he also does not claim to be a tree-hugger in any way, shape, or form.
Jan 14, 2015 at 2:45 PM Post #655 of 2,104
My gear, tube gear included, only gets turned off by power outages as well.  Things tend to fail on state change more than constant state.  Ie on power on, disconnect, moved, jack insert etc.
Jan 15, 2015 at 11:21 PM Post #656 of 2,104
My 10.33 came in... happy to say I am quite enjoying it, thanks again, Zach!
I'm impressed by the build quality. It sound great with my speaker setup too boot.
I'm especially liking the usb32, as I've never really been a fan of usb. It was quite the surprise that the usb was on equal level as the spdif...
That said, I cannot seem to get Asio working, is there something I'm missing by follwoing Kingwa's posted directions on the download page? I'm using Foobar, and asio has never been this tricky before.
Jan 16, 2015 at 2:52 AM Post #657 of 2,104
You can try this step by step procedure http://download.yamaha.com/api/asset/file/?language=en&site=europe.yamaha.com&asset_id=59782
Start from page 3 assuming you have already installed the Audio-gd driver. Of course, select Audio-gd instead of Yamaha.
Jan 17, 2015 at 8:49 AM Post #660 of 2,104
  Hi there!
Anyone using this to power a LCD 2.2F? How's the amp's sound "signature"? I wonder if this is a bright or warm amp...
Also is the USB-32 and ES9018 upgrade worth it?
I guess the question is, what are you upgrading from?
The ES9018 chip is inherently a little bright with good details, but the Audio-GD implementation is very good, making it smooth, detailed, punchy and dynamic.   It should work great with the LCD's,I loved it with my HE-500.
If you use USB than the upgrade is worth it, as the USB-32 sounds great.
