DaemonSire
- Jan 24, 2012
Will do shortly.
Can the source be different eg. USB - PC, optical - PS3?
Awesome, thanks!
Yes it can. That's actually exactly how I have it set up right now for testing a separate optical source. USB to PC and Optical to PS3. Once you turn on the PS3, you can switch to it if you'd like and hear the main menu sounds when you scroll around. Switching back to USB, the internal muting relay should no longer 'click'. Then as soon as you turn off the PS3, the muting relay click will return.
In my case at least
