The first and only negative review on this DAC/amp.... Is it really underpowered to drive an HE-6? Anyone else experience the popping issue on changing sources? Link below and excerpt from the link translated
http://www.auriculares-hifi.com/foro/index.php?topic=822.0
After trying three headphones as different profiles, and seeing the synergy obtained with each handset, I can almost ensure great
versatility of this combo with most headphones in the market.
With that I like are the orthodinamic instead very sensitive and very low impedance headphones, caught some annoying background noise. Modifying a Jack input cable 6'3 "to XLR is very cheap, just have to change the connector, you can also buy a cable XLR finish. For me, Paco de
Cables Hamlet , I drew up one XLR finish.
UPGRADE TO 10/03/2014. 6 MONTH AFTER I got it half a year ago and I've tried many headphones and more to know me pat.takes In General extraordinarily well balanced with orthodinamic in, I tested the Audeze LCD-2, LCD-X, hifiman HE-500 and HE-6 hifiman "latter not moving well" was my surprise to see that the Schiit Lyr at that impedance has 4W was more capable than the Audio-Gd with the HE-6. This gives the feeling that the power given Audio-Gd on your device comes quite exaggerated. I've tested many different headphones and combo is completely neutral, not only provides warmth, brightness or none. Jumpers Probe to increase the warmth, not only had no more serious note, if not noticing the sound worse with jumpers posts. as the combo becomes darker and lacking in detail. A huge disappointment from the jumpers to increase warmth. With dynamic low impedance and nothing was very sensitive along. With the Denon AH-D7100, AH-D600, D340 and AH-P7 Bowers Wilkins caught me a noise background very annoying. When you give volume or you take away volume up or down the noise, it's like a "coupling" They have a very good synergy with the 6X0 range of sennheiser, however the HD800 Sennheiser not end convinced me to the Audio-Gd. Sound too "thin" and some "aggressive" Then also detect when you use it only as Dac connected to an external amplifier, does not the headphone amplifier. , and what worries me the most of the device, when you change the channel headphones connected to the input of channel 1 to channel 2, etc .... or when you change Dac / HP. Paste as a petardazo, I've had more of a scare with my headphones on. It is a petardazo that gives the feeling that it is dangerous for the headphones. I imagine there will miss a very straightforward design for better sound quality, In fact I just heard the combo with the computer and do not usually touch the input, but day I did more testing apparatus, paste me a scare that fabric. Best of Combo is the Dac and its value is devastating. But I have found these faults and apparently not only does my NFB-28.
Where'd you bought? manufactures directly because
www.audio-gd.com , I personally attended the Sr.Kingwa through your e-mail
audio -gd @ 126.com http://www.audio-gd.com/Pro/Headphoneamp/NFB28/NFB28EN.htm gave me a choice of shipping by
EMS or
DHL .payment is made through
paypal . Note that as the dollar being devalued against the Euro the price was fantastic. combo goes to change about
553 Euros ($ 750).
