littletree76
- Nov 5, 2005
You have to compare electrical parameters among specifications or perform measurements on outputs to decide how much off-the-self 3-pin linear regulator is worst than discrete linear/Class A. While data sheet for any 3-pin linear regulator is available form manufacturer's website, specifications for discrete linear/Class A are only available from equipment designer (such as Kingwa from Audio-GD). So as a buyer, I can only speculate based on the fact discrete implementation must be better than integrated circuit product and performance of audio equipments heavily depends on good power supply implementation.
Take note that the discrete Class A design is referring to output regulation of power supply but not buffer/amplification stage of DAC though it can be applied for both purposes. Power supply with class A regulation and amplifier with class A amplification are two different things with similar circuit design.
So, 3-pin linear is significantly worse (vs. Class A) aurally ? For example NFB-1 against NFB-10.
Quote:Just update the FAQ
http://www.audio-gd.com/Agents.htm
