I am in the same situation as you. I am considering all Audio-GD DAC models below USD 1000 (NFB-1WM, NFB-10WM, NFB-2/NFB-3) built with dual WM8741 DAC and WM8805 receiver to replace existing StageDAC (dual WM8741 / WM8804 receiver). I suppose Audio GD's output stage built with discrete components produces more neutral and natural sound signature than those built with op-amp integrated circuits (designer has perfect control of electrical parameters of the output stage).
My considerations are based on some rationales as follows:
Power supply implementation:
NFB-1WM -- Discrete x5 / R-Core Transformer x2
NFB-2 -- Discrete x6 / Linear x1 / R-Core Transformer x1
NFB-3 -- Discrete x2 / Linear x5 / Toroidal Transformer x1
NFB-10WM -- Discrete x7 / R-core Transformer x1
NFB-2 has better power supply than NFB-3 as difference between discrete power supply unit and off-the-shelf 3-pin linear voltage regulator (such as LM317) can be quite substantial for audio circuits. All power supply units for NFB-10WM are discrete. NFB-1 has the best power supply implementation as power supply units for logic circuits and analog circuits are completely separated and all supplied by five discrete power supply units through two R-core transformers. So as far as power supply implementation is concerned: NFB-1WM > NFB-10WM > NFB-2 > NFB-3.
Digital inputs:
NFB-1WM -- Coaxial / Optical / BNC
NFB-2/3 -- Coaxial / Optical / USB
NFB-10WM -- Coaxial / Optical / USB
For NFB-2/3 and NFB-10WM models, buyer can have customized build with USB input replaced by BNC input but 20 days is required for building and testing. As far as my application is concerned (not involve computer), BNC input is more flexible than USB and it can be supplemented by Audio-GD's Digital Interface or M2Tech's HiFace/Evo to provide much better USB interface than the on-board one.
DAC line outputs:
NFB-1WM -- ACSS / XLR / RCA
NFB-2/3 -- ACSS /RCA
NFB-10WM -- ACSS / XLR / RCA
If you need two line outputs to power amplifier and external headphone amplifier like me, having both XLR and RCA outputs is more crucial than ACSS output. With ACSS interface, choice of amplifiers are quite limited as far as I know ( mostly those models produced by Audio-GD) though this current interface is much better than voltage interface such as RCA. The balanced XLR output can be converted into unbalanced RCA output easily by shorting negative and shield terminals. Thus NFB-1WM and NFB-10WM provide more flexible line output interfacing than NFB-2/NFB-3. Since NFB-10WM can be used as pre-amplifier with volume control, its XLR and RCA output levels can be made variable by changing jumper position in main PCB board. For DAC line outputs: NFB-10WM > NFB-1WM > NFB-2/3
Headphone outputs:
NFB-1WM -- NIL
NFB-2/3 -- NIL
NFB-10WM -- Balanced x1 / Unbalanced x1
Both balanced and unbalanced headphone outputs are available on NFB-10WM with 32-step digital volume control (through ADC, relays and banks of resistors). Channel imbalance is kept to minimum and its balanced/unbalanced headphone outputs allow user to have trial of balanced headphone at minimum cost. For headphone outputs: NFB-10WM > NFB-1WM > NFB-2/3
After these comparisons, I am leaning toward NFB-10WM for all-in-one solution (good upgrade for FUN/Sparrow owners). But prices for NFB-1WM and NFB-10WM are the same and I am not sure how much sound improvement NFB-1WM has over NFB-10WM. I have to wait for reviews on sound quality for these two new products. Hopefully Kingwa can provide opinions on sound quality of these two models to allow buyers to make early pre-order decisions before end of this month.
thank you for this ... now, must decide between nfb-2, or -3, or go the combo route with the -10.
