abitterlemon
Thanks for the reassurance JaMo. I hope you are right.Hi abitterlemon,
There is no reason to worry. Kingwa and Audio-gd are very honest. They have a lot to do now. You will get confirmation and the gear.
/Jan
/Jan
You should be able to loosen and pull it out with a thin knife for example.How do you guys remove the top plate btw? After removing the screws I still find it hard to remove it as it is recessed and tightly fitted to the chassis with no place for grip to take it out.
Don't use sharp objects, that will definitely make scratches on the black aluminum.
Use something like duct tape. Stick it partly on the top plate, and then with a short pull you can take the lid off.
Yes don't use knifeWhoa no way am I using a knife lol. Even my fingernail gave it a scratch!
I'll try a duct tape, but doesn't feel like it'll help much since it is quite tightly fit into the chassis.
Yes don't use knife
I opened it with gopro glass mount with its suction cup. Also if you have car phone holder on windshield, you can use it.
The switch on the back is for cutting the amp when no signal is received (in order to leave it always on if you wanted to do so)
Quick question. I've had my NFB-11 (2015 version) for a few months now. I have one problem. Whenever I play something, it usually takes a second, has a small pop, and then starts playing. Then when I pause it, it pops again after a few seconds. Then I have to repeat the process. Is this normal? I can live with it but I'd rather not.
