unclebrudy
There are many uses for many people regarding fixed and variable outs - I'll give you mine for example(s).FredA, THANK YOU very much for that information. I appreciated it.
I wonder what Audio-GD was thinking with the fixed mode. What purpose does it serve?
Fixed mode is just that - fixed line output that is not affected by the AGD's volume knob, typically around ~2vrms like many standalone DACs. I use fixed when outputting to my Little Dot MKII, and use the MKII's volume control. I use Variable when outputting to my powered speakers. My speakers have a volume control, but they are inconvenient to reach for (and I lost the remote, but that's a different story) and using the AGD as a preamp (i.e. - its volume knob for control) is tons more convenient. I also used to have it split to a power amp I was using for a previous set of unpowered speakers - same thing, preamp volume control, except in this case the power amp didn't have a volume control so it was a black and white need.
While you can use Variable out in conjunction with another amp that has its own volume control, you'll introduce clipping if you turn the AGD's volume pot past ~halfway, at least in my experience. On my NFB-15 and previously owned NFB-11's and R2R 11, 12 o'clock on the pot was pretty close to the same volume as Fixed out, and there's distortion and clipping too far past that. Plus, two volume controls for one output is pretty redundant.
