USAFPharm86
I think comfortwise the Sundara is on par with the older Hifiman headband style on the HE 560 which is that same as on your headphones (I’ve read initial complaints about the Sundara because the earpiece doesn’t rotate about the vertical axis but I think most get accustomed to the fit).
Regarding the hotspot you’re getting, it’s strange because I don’t recall many people saying that about Hifiman headphones because they’re relatively light. A couple of things to try:
- try to place the headband strap on the flat (front to back) part of your head because ithe strap has no front to back curvature
- extend the earpieces a little more to relieve the tension at the top of your head
- carefully bend the headband to adjust the pressure in your ears
I hope this helps.
I think the hotspot is related to me trying to bend the 400s headband in the past to adjust the pressure around my ears. I bent it back to the normal position and now more clamping force on the earcubs and less pressure on the top of my head. I don’t think I can win or my head just doesn’t like hifiman headphones haha.
The old headband on the Hifiman HE-500 does not cause this hot spot, I think the comfort issues probably come from the weight.
I might look into getting a ZMF pilot pad to see if this increases the comfort.
Thanks again.
